Hi Guys
right i seem to be having abit of a problem with one of my decks they are technics mk2 1210s.. well to the problem, when i set the pitch on DECK A via the pitch control to 8% VDJ seems to say its going @ 12%.. where as the other deck i set it to 8% and it says 8% in VDJ which is fine.. are you able to confirm whether is the software or the deck itself?
Thanks
~DJ Shaikly~
Thanks
~DJ Shaikly~
Posted Thu 22 Feb 07 @ 6:02 pm
Just an idea, but check the deck calibration - although that might be rather tricky unless you have access to the right gear - like a B&K stroboscope or a CRO etc... Could be a worn pot. Also, did you configure the timecodes while the pitch slider was in the centre on the Technics? I know it's obvious but you never know, sometimes it's that simple.
Posted Fri 23 Feb 07 @ 3:30 am
