i have the old atomix mp3 brake and swirl plug in, but it doesnt work on virtual dj 4.2. i am trying out the trial version. is there any way to make it work on the 4.2 trial version.
Posted Tue 20 Feb 07 @ 11:39 pm
its a different coding.
Posted Wed 21 Feb 07 @ 10:46 am
but can you switch it over to the 4.2 format. if i can do it i will buy virtual dj pro version
Posted Fri 23 Feb 07 @ 4:50 am
if you can program you could try to modify it
http://www.virtualdj.com/addons/effects.html these are fx for 4.2 maybe you will like them just as much :)
Posted Fri 23 Feb 07 @ 9:29 pm
