Topic: mk2 sound card/mixer
howdy all
can the hercules mk2 act as a stand alone mixer/soundcard or do you still need to
connect it to another mixer or sound card.
thanks
musicman
Posted Fri 16 Feb 07 @ 3:36 pm
You can use it as your mixer and soundcard however it will not function unless it is attached to the computer. If this is the plan then yes you can use only the MK2.
Posted Fri 16 Feb 07 @ 7:01 pm
see skyfxl ultimate guide to controlers.....
Posted Fri 16 Feb 07 @ 10:24 pm
sbangsPRO InfinityMember since 2004
Posted Fri 16 Feb 07 @ 10:29 pm
