am new to virtual dj, Ive downloaded the tiral verison 4.2, but after a couple of days using it, for reason the "loop in" function will not work at all... Ive tired every thing, restarting the computer etc, even deleted the program and redownloaded it still nothing??
Posted Fri 16 Feb 07 @ 9:06 am
From what i understand about the loop in function is it a starting point.. So while your track is running you punch your loop in at the point you want the loop to start and punch the loop out at the point you want the loop to start looping...the loop out light will be RED while the track in looping when you want the loop to finish to punch out the loop out button.....Hope this making sense for you...!
Posted Fri 16 Feb 07 @ 10:28 am
Yes I understand that thanks, but the function is just not working "loop in" but the loop out works just fine?? how do I fix that??
Posted Fri 16 Feb 07 @ 9:11 pm
try a reinstall
Posted Fri 16 Feb 07 @ 9:32 pm
I already tired deleting it and restalling it, still nothing. when the hit the loop in button, nothing happens, I have a newer fast computer so I dont understand why this is happening?
Posted Fri 16 Feb 07 @ 10:47 pm
