Hi all,
i've been trying find the post that tells you how to disable the cbg, and just use the peaks when using auto mix and sync.
can anyone point to the post, or help me disable the cbg, as its not accurate enough for my type of music :( ( not even adjusting bpm manually helps :( )
thanks
thanks
Posted Thu 15 Feb 07 @ 5:31 pm
