i want to hook up my laptop to my turntables that i just ordered with the vinyl...i have the dj console mk2
as my sound card
as my sound card
Posted Thu 15 Feb 07 @ 6:31 am
connect like this
when your timecoded vinyl arrive place them on the turntable
choose inputs : timecodes
outputs : headphones
card : asio
driver : mk2 , ensure on the mk2 console software , Asio is selected as the mode
now go to timecode config window and play the vinyls , on the options screen press auto configure a couple of times until you have 100 % quality
all is now good to begin :)
if you get stuck or need photos to follow steps check my guide here :)
https://virtualdj.com/forums/58120/Hardware_Technical_Support/Guide_To_set_up_tcv_with_mk2_console__)_.html
Posted Thu 15 Feb 07 @ 12:57 pm
show me how to use 2 different soundcards for tcv in a diagram please:)
Posted Thu 15 Feb 07 @ 5:50 pm
https://virtualdj.com/products/timecode/
just choose dual soundcard mode choose those two cards and connect the decks to the line in of each card.
Posted Thu 15 Feb 07 @ 6:21 pm
