¿¿ VIRTUAL DJ 4 vinyl ??
Hi, i am Doctor Space (Spain->Barcelona)
http://www.youtube.com/watch?v=M7dyjIbJ_38
English (google translate) It is possible to have a version that has 4 vinyls instead of 2 habitual ones as it has the program, not to have to use 2 virtual DJ. Thanks! ( sorry my english )
Spanish text: Es posible tener una versión que tenga 4 vinilos en vez de 2 habituales como tiene el programa, para no tener que utilizar 2 virtual DJ. Gracias!
:þ
Posted Mon 12 Feb 07 @ 6:38 pm
try the spanish forum maybe it will be easyer to explain your problem here :)
http://www.virtualdj.com/forums/12/Spanish_Forum.html
Posted Mon 12 Feb 07 @ 6:51 pm
My spanish is not so hot, but I'll give it a poke....
necesitas la piel VMIX Multi-Instance de DJ Cyder. permitirá que utilices dos VDJ al mismo tiempo. con 2 tarjetas de los sonidos, debes poder jugar 4 expedientes..
I hope you get the idea mas o menos...
-Steve
-Steve
Posted Mon 12 Feb 07 @ 6:58 pm
thnx you!
Posted Mon 12 Feb 07 @ 11:36 pm
