I have had horrible problems trying to get my BCD2000 to work with VDJ 4.1. I hope someone can help me:
At first I had problems where everything would work fine for about 30 seconds and then it would crash (the music would stop playing and the buttons will not respond). If I went into the config and changed the settings it would start working again, but then stop a few seconds later and I would need to restart.
By changing the settings to "Simple Audio" I can get it to work fine without any crashing (screenshot here: www.zascar.com/files/Setup1.JPG) however I cannot preview/monitor with the headphones - it just plays whatever the speakers play.
If I change it to what it should be (www.zascar.com/files/Setup2.JPG) - with the outputs to the headphones and the BCD2000 as the sound card - it either does not work at all or crashes within a few seconds.
Can anyone suggest how I can fix this?
Thnaks
Thnaks
Posted Mon 12 Feb 07 @ 10:04 am
Sorry the links did not work correctly, here are the two screenshots:
http://www.zascar.com/files/Setup1.JPG
http://www.zascar.com/files/Setup2.JPG
Posted Mon 12 Feb 07 @ 10:05 am
Try these..
Output : Headphones
Sound card : ASIO Driver
ASIO driver : BCD 2000
Select from the performance
presets ...all the way left to fastest
Latency ... AUTO
Overclock check
Deactivate as many softwares as you can (Antivirus, wireless etc)
Give it a try.
Output : Headphones
Latency ... AUTO
Overclock check
Give it a try.
Posted Tue 13 Feb 07 @ 12:50 am
DJ Dad
Thank you SO MUCH this works perfetly now - i;ve been trying to get it working to no avail for monthsl...
Thanks again
Thanks again
Posted Fri 16 Feb 07 @ 9:43 am
colinfitz wrote :
DJ Dad
Thanks again
Thanks again
Now that everything works perfectly, I think you're conviced about vdj, and it will be time to acquire a legal version.
Posted Fri 16 Feb 07 @ 2:33 pm
