I need help on setting up my DJM 800 to work with virtual dj. Can someone please give me step by step instructions on how I can accomplish to have the crossfader on the DJM 800 do the controlling of the audio/video on the virtual dj. Besides a midi caple whats else will I need. What setting do I need to change in virtual DJ.
DJ Angel S
DJ Angel S
Posted Mon 12 Feb 07 @ 2:37 am
check this out for midi mapping :)
http://www.virtualdj.com/forums/62907/PC_Version_Technical_Support/Asorted_Software_Guides__(common_fixes_and_tweaks_and_how_2_s).html
Posted Mon 12 Feb 07 @ 2:47 am
Please Skyfx
I don't want to searcha around, I just looking to see if someone could respond to my post. I still and evaluating to see if I going to go ahead a purchase. I still have like 6 days on the demo. This is what I was refering to when I last posted about have a contact person from customer support.
DJ Angel S
DJ Angel S
Posted Mon 12 Feb 07 @ 2:52 am
k here is the text copied for u
9. midi mapping
9. midi mapping
Posted Mon 12 Feb 07 @ 3:00 am
aslo on options go to the video tab and tick link video and audio faders
Do I need to do any settings on the DJM 800
DJ Angel S
DJ Angel S
Posted Mon 12 Feb 07 @ 3:02 am
no you just need to map the activities you want by following those steps until all the buttons you want are enabled :)
Posted Mon 12 Feb 07 @ 3:03 am
The settings for using the crossfader for mixing audio and video is?
DJ Angel S
DJ Angel S
Posted Mon 12 Feb 07 @ 3:10 am
Skyfx
I forgot to ask about midi cables. I do not have a connection on my laptop for mdi. Will a M Audio usb to midi cable work for the connection of the laptop and DJM 800
Dj Angel S
Dj Angel S
Posted Mon 12 Feb 07 @ 4:43 pm
yes that should be fine
Posted Mon 12 Feb 07 @ 5:51 pm
