when i go to use vinyl it says that the ASIO driver cant be found ect.. What is ASIO and does the hercules have it?
Posted Sun 11 Feb 07 @ 1:37 am
what version are you using?
Posted Sun 11 Feb 07 @ 1:42 am
Audio Stream Input Output.
The Hercules console supports ASIO and has drivers for it.
Posted Sun 11 Feb 07 @ 1:43 am
well right now i have the verson 3.4. but i downloaded the trial of virtual dj pro and i want to see if it works with timecode.
Posted Sun 11 Feb 07 @ 1:44 am
and i have the denon dn-s1000.
Posted Sun 11 Feb 07 @ 1:46 am
ok on the mk2 control pannel ensure you have choosen asio mode
then on vdj sound options choose card
asio :
mk2 driver
now all should be good
if still having problems check here
http://www.virtualdj.com/forums/58120/Hardware_Technical_Support/Guide_To_set_up_tcv_with_mk2_console__)_.html
asio :
mk2 driver
Posted Sun 11 Feb 07 @ 1:47 am
can i also do the same with numark cue? because i might buy that.
Posted Sun 11 Feb 07 @ 1:49 am
vdj 4 pro and numark cue is the same
you will get a discount if you by virtual dj pro download however
as you own the mk2
discount
as you own the mk2
discount
Posted Sun 11 Feb 07 @ 1:53 am
ok.....i went on the thing that you told me to go to. i did everything that it told me to do. but, when i played my timecode cd all it did was some stupid thing where i couln't scratch. it also just played very slow backwords. its not working???????? :((
Posted Sun 11 Feb 07 @ 4:15 am
