hello all
just downloaded this software to have a play and see if it lives up to all the hype, the one thing i cant seem to figure out is were the beatlock is?
it seems to go out quite a lot, looks good apart from that
cheers
cheers
Posted Tue 06 Feb 07 @ 1:16 pm
If you press Shift + 'B' on the deck you want to beatlock, you'll notice the 'Sync' button being highlighted on the screen. You've just beatlocked. To deactivate, just press Shift + 'B' again...the highlighted button will go back to normal.
If it's not shift and b try just pressing B. I don't use a keyboard for beatlock anymore so I don't quite remember all of the keyboard commands...however, you may be able to check the assigned keyboard shortcuts in the config panel.
Welcome to Virtual DJ!!! Hope to see you as a full user real soon.
Keep spinnin'...(",)
P
P
Posted Tue 06 Feb 07 @ 1:49 pm
check my blog for a full list of shortcuts :)
Posted Tue 06 Feb 07 @ 2:39 pm
thanks for the help guys, thats sorted that out.
Posted Thu 08 Feb 07 @ 12:03 am
