For those of you who prefer to use winamp library to find music.
step by step.
--winamp--
find: use winamp library to find the song you want.
select: select that "1" song
file info: press and hold "alt" + "3" OR right click "View file info"
source: In the file info box at the top you will see the full disc and directory source of that music.
copy: highlight, then copy, i use "ctrl" + "c"
--virtual dj--
serach: search in "Local DataBase"
paste: in the search box paste the line of text you just copied from winamp. i use "ctrl" + "p"
find: assuming that song is in your library.
load: that one song is that exact song. go ahead and load it.
vwala.
DJ Shahar
www.djshahar.com
step by step.
--winamp--
--virtual dj--
vwala.
DJ Shahar
www.djshahar.com
Posted Sat 03 Feb 07 @ 2:29 am
