Hi I have a bcd2000 and have connected it all up and installed the drivers but when I configure it to work with the bcd2000 the tracks won't play. Everything else works like the bass cuts and the crossfader etc but its just the play button and it wont work even if I press the play button with the mouse. Has anyone had this problem? or does anyone know what I am doing wrong? thanks in advance.
Posted Thu 01 Feb 07 @ 5:36 pm
are you using the latest demo
check dj qunitanas block :)
Posted Thu 01 Feb 07 @ 11:02 pm
I have the same problem at first time .
go to BCD2000 console panel and change the confg. (B-DJ) to (ADVANCE)
thats all. this resolve my problem.
Posted Fri 02 Feb 07 @ 3:31 am
You may have to update the driver to the newest 1.1.1.0 this fixed the bug I had that sounds like what you have.
go here to down load it:
http://www.behringer.com/05_support/bc_download/bc_downloads.cfm?lang=ENG
Posted Fri 02 Feb 07 @ 8:03 am
From the sound setup of VDJ select Latency "Auto", the performance fader all the way to left and Overclock ON, Safemode OFF.
Update drivers and try to deactivate any software not needed (antivirus) and of course Wifi (wireless) and bluetooth if available.
Upgrade your RAM
Posted Fri 02 Feb 07 @ 6:00 pm
