Forum: Old versions
Topic: will skins work with vdj mac ?
just wondering bout skins, will they work with the mac version
Posted Wed 31 Jan 07 @ 4:16 pm
sbangsPRO InfinityMember since 2004
well they do support xml , which the skin engine is based
it depends how similar the interfaces are
options may have to be different
and skins might need to be redone
plugins will need to be compiled in a different way prehaps as im not sure to what extent a dll file can be read in mac os
the only ones who can give a definative answer on this one
are the dev team.
Posted Wed 31 Jan 07 @ 4:20 pm
Stank you very much ;).... I hope they can get it poppin
Posted Wed 31 Jan 07 @ 4:21 pm
frd1963PRO InfinityMember since 2004
I'm no VDJ spokesperson, but I don't see any reason why the skins would be completely portable between the 2 versions. It should b the same program, same functions, etc. just running on a different platform.
The VDJ programmers aer professionals so I'm sure they will keep everything transparent to the user.
Posted Wed 31 Jan 07 @ 8:45 pm
mac and windows have different programing in some areas
Posted Wed 31 Jan 07 @ 9:20 pm
skins do work, effects and transitions need to be in a different format called a bundle, as .dll's don't work in mac.
Posted Thu 01 Feb 07 @ 9:54 am
have you tested this?
Posted Thu 01 Feb 07 @ 10:21 am
Steve might ;)
Posted Thu 01 Feb 07 @ 11:14 am
very nice ;)
Posted Thu 01 Feb 07 @ 2:05 pm
