I need some help,
i currently have the a pioneer cdj 1000 & a pioneer cdj 1000mk3 hooked up to the bcd2000.
i have the the trail version of vdj...
i dont know whats wrong with signal to the cdj 1000mk3
everything runs.. but it crashes all the time :(
whats wrong! lol
whats wrong! lol
Posted Fri 26 Jan 07 @ 10:54 pm
its to loud use an audio editing program to reduce the timecode mp3 13 db
then burn another disk will work fine ;)
try audacity ;)
try audacity ;)
Posted Sat 27 Jan 07 @ 12:27 am
You are using tccds and bcd2000 only has 2 phono in and 1 line in, although you reduce the signal to the minimun you will have that problem, the inverse riaa plugin is now included in vdj 4.2 buy still needs some modification in order that works correctly to convert the phono in into a line in,regards.
Posted Sat 27 Jan 07 @ 6:05 pm
is there anyway to use tccds with the bcd2000 without any problems?
Posted Sun 28 Jan 07 @ 11:47 pm
