Can all the DJs using laptops please recommend quality 2 channel stereo external sound cards that work well with laptops (Dell)?
I bought the M Audio Fast Track Pro USB sound card. Tried for hours to install the drvers onto my brand new Dell Laptop..... I spent another 2 hours with M Audio support trying to set it up. They could not help me get the laptop to recoginze the drivers..... I could not believe it was this difficult to get an external sound card to work. I installed the M Audio on my destop at home and sure enough, although I could not get it to work, VDJ recognized the ASIO drivers.
My Dell Laptop 1505 is brand new, XP pro, dual core, 2 G ram, and is only used with VDJ. I have 3 unused USB ports and no IRC conflicts..... I have read a few reviews of the M Audio where people stated it was difficult to set up....
I just ordered a GIGAPORT AG....
What external sound cards work the best with laptops???
Any and all comments are appreciated. Thanks...
CM
CM
Posted Tue 23 Jan 07 @ 2:52 pm
i'm running the same pc with a u46 and have no problems
Posted Tue 23 Jan 07 @ 3:02 pm
one of the most popular is the
Hercules DJ Console MK2
look at the "show us your gear" topic
midi controller designed for vdj,
4.1 sound card.
compatible with timecodes tccd or tcv
microphone input
only problem is that the tech support of Hercules are "profoundly retarted" notice the quotes
oh yea, there is some kind of issue with the increasing hissing sound. not so sure yet how to solve it.
DJ Shahar
www.djshahar.com
4.1 sound card.
microphone input
DJ Shahar
www.djshahar.com
Posted Wed 24 Jan 07 @ 1:35 am
two recommended pro units
gigaport
presonus firebox
gigaport
presonus firebox
Posted Wed 24 Jan 07 @ 2:11 am
My laptop is a pretty similar spec djkizzle and i use the u46DJ. Never had any problems with it thus far.
Posted Wed 24 Jan 07 @ 5:39 pm
Presonus Firebox.
Quality, easy to setup, reliable, great sound, phone support if needed!
Dell XPS, TCCD
Enjoy!!
B
Dell XPS, TCCD
Enjoy!!
B
Posted Thu 25 Jan 07 @ 6:06 am
I am running Echo Indigo DJ and E-MU 1616M. Another popular external soundcard is Motu Ultralite. Check out this website for a list of much more: http://www.audiomidi.com/master.cfm?CID=103
Posted Thu 25 Jan 07 @ 8:19 am
Hi
I have got the Maya ex 5, Had for the past two years no problems,easy to instal
Cheers Musicmatch
Cheers Musicmatch
Posted Tue 20 Feb 07 @ 4:12 pm
