Ok guys so Im playing a song and everything runs smooth, except when i Load another track on the other side it makes this noise when it its reading the file, like it starts to stutter im running with Timecoded Vinyls
Turion 64 1.8 Laptop
80 Gig
1 Gig ram
TT500
Hercules mk2
Is there any way to make this process run smoothly without this embarassing stuttering while the file is loading? Do i have to tweak my windows?
would appreciate the help!
80 Gig
1 Gig ram
TT500
Hercules mk2
Posted Sun 14 Jan 07 @ 5:24 pm
lower your proformance tab
still having issues choose"autolatency"
Posted Sun 14 Jan 07 @ 6:13 pm
No luck. Its really sad to know the potential of this software but i will not give up! Ok i tried using my Mk2 with the program alone and it worked SEAMLESSLY... no Problems Until i Went ASIO and Added the Vinyl when i loaded another track on the other deck it made "noises and slowed down the current song playing", is there any other way to boost this process?
another question..If i only want to run VDj on this laptop without running all my other programs, how can i do that? i read your post but no luck
Posted Mon 15 Jan 07 @ 4:32 pm
Try setting latency to AUTO in VDJ performance tab
And turn OFF safemode and overclock
Posted Mon 15 Jan 07 @ 4:43 pm
I've run into audio issues using TCV and the Hercules Asio driver... download ASIO4ALL at www.asio4all.com and give that a try as your ASIO driver... It seems to have done wonders for my laptop rig.
Posted Tue 16 Jan 07 @ 1:58 pm
if you want to try the asio for all driver
check my guide on how to install it here
http://www.virtualdj.com/forums/62907/Software_Technical_Support/Asorted_Software_Guides__(common_fixes_and_tweaks_and_how_2_s).html
Posted Tue 16 Jan 07 @ 2:47 pm
