Forum: VirtualDJ Skins
Topic: need urgent help!!!
just bought virtual dj mixstation 3, and cant seem 2 use any downloaded skin?? when i go to the skin menu, and try to select a skin, it just pops up 'invalid skin file (error in line 20)???
can some 1 please help asap as i hate using the mixstation 3 default skin
thanks
Posted Sun 14 Jan 07 @ 5:21 pm
cstollPRO InfinityMember since 2004
I believe that DJ Mixstation 3 is based on the VDJ 3.4 engine - What this means is that the only skins you should download should be the skins listed for VirtualDJ 3.4.
Don't try to use any of the VDJ version 4 skins.
cstoll
Posted Sun 14 Jan 07 @ 6:03 pm
sbangsPRO InfinityMember since 2004
which skins ? did you try
Posted Sun 14 Jan 07 @ 6:11 pm
JeremKPRO InfinityModeratorMember since 2004
DJ Mix Station 3 is based on VDJ 2.3 this is quite an old version.
Try looking for skins based on 2.xx version.
Posted Sun 14 Jan 07 @ 10:29 pm
