Hey i was just wondering if you can make ur bmp in vdj steady, because when i play any song it changes for example (127.7 , 127.9) and also whats the best pitch in vdj to adjust bmp manually -8 +8, or -12 +12? or -34+34
thanks
thanks
Posted Thu 11 Jan 07 @ 7:32 am
That small movement in the bpm is really irrelevant for the most part and won't affect beatmatching. As far as the pitch range that is up to your mix style. The larger the range the more you can adjust speed. So if you plan on mixing 140 bpm song with an 80 bpm song (not too likely), use key lock and the -34 pitch settings. I usually just use the default which I believe is the -12 to +12.
Posted Thu 11 Jan 07 @ 5:12 pm
Are you using a controller?
Posted Fri 12 Jan 07 @ 9:07 am
