Topic: Korg pad kontrol or Radium M-Audio Midi
Does anyone know if you can map or effectively utilize any of these Midi controllers for Use with DJ or video in VDJ? Anyone who might have an idea is more than welcome.
Posted Sun 07 Jan 07 @ 1:08 am
korg is more of an fx unit than a controler , get the radium :)
Thanks. I have both.
are you talking about the 16 key raduim m-audio midi controller?
i am thinking of getting it
would be awesome for samples and changing pitch controller right into vdj--if that works?
does it???
i use to have a roland 10 keyboard back in the day--long gone
what does everyone map for???
hot keys?
samples?
loops?
all on the above?
driving directions?
lemme know
thanks in advance
I have a 66 key Radium and tried to map it several months ago in the early 3.0 versions with not a lot of successs. Some things worked, some didn't. I am yet to try it with 4.1 or 2, but have been busy implementing other sequencer software like Mackie Tracktion 2 with it and recently acquired the Korg Pad Kontrol for additional midi and it's highly rated pads for live percussion effects in remixing and performing along. My hands are full, not to mention I use it for video remixing, playing and HD recording ALL at the same time Live. I will keep you posted.
