Topic: Numark Virtual Vinyl (Vinyl Timecodes)
I was curious will Numark Virtual Vinyl Records work with virtual dj program? I definetely want to purchase this software over serato but replacement vinyl for serato is alot cheaper but if you could use Numarks Vinyl when its released then that would be a big plus.
Posted Fri 05 Jan 07 @ 10:30 pm
yes it will :)
you also get a copy of numark cue (virtual dj with a special skin)
when you buy it
Yes ;it will work ~they are the same program ..just different packaging
dangit sky!!! what you got speed type on or somethin....lol
Ok,, we buy Numaks hardware we get a copy of CUE.. Will Numaks plugins and Video extras work in VDJ.
all plugins will be the ones from www.virtualdj.com
cue users will have the same acess as a pro vdj purchaser.
about 200 words per min lol
On Numaks sit it reads “Library of small movies, pictures, graphic sets supplied”,..
Will we be able to transfer these file to VDJ.. This comes with CUE, and like VDJ file extensions,, will we need to change the file extensions or will they work as is.??
@ paulettecerra:now thats a good question!!
nope they are just video plugins and visuals from here lol
u can copy and paste between plugin folders :)
Numark CUE is only sold boxed, and comes on a DVD.
The install includes a wide sample gallery of video clips etc.
They are NOT available from VDJ site, and are promo material Numark have collected.
The Cue install is about 200mb
The samples will of course work in other apps, and are not some native format for CUE only
looking at the mac installer for the other dj software i use. it's less than 2MB. that was not a typo :-)
hehe ;) yeah..
the CUE download trial is about 12 mb or so...
Its the full DVD version thats 200mb, but it contains A LOT of samples of videos etc :)
