Forum: Old versions
Topic: Resource-Problems ?
Hi,
i have a question. I have sometimes problems with my MP3 console.
If I do any manipulations on my MP3 console (push prelistening button ex.), the song playing jumpes sometimes. Sometimes if i did a mix, and let the quiet song playing till at the end, that can cause also jumps. The peak announcement comes to a hold at the running song.
I tried out a lot of things with the config on my Laptop. All drivers who aren't used are switched off, the memory is optimized, i'm sure it isn't the configuration. have anyone a tip for me?
System :
Laptop Acer, Centrino 1.6 Ghz, 533 FSB, 1 GB Ram, XP
80MB HD NTFS, Songs are on a external USB (USB 2.0) 160 GB HD, NTFS
Soundcard Creative Audigy SZ 2, 5.1 PCMCIA
Audigy SZ 2 driver is actual, Hercules Driver also.
I use Virtual-DJ 3.4
Posted Fri 05 Jan 07 @ 1:45 am
ok, lemme see, have u tryed this?
lowering your perfermance tab? and putting vdj to AUTO LATENCY ALL THE TIME!!!!!!!!
Posted Fri 05 Jan 07 @ 6:38 am
AUTO LATENCY ALL THE TIME - where i can do that ??
Posted Fri 05 Jan 07 @ 4:55 pm
sbangsPRO InfinityMember since 2004
try defraging your computer with www.diskeeper.com , and other optimisations
and try tweaking your computer
check my blog for more tips :)
ps
wess
he doesnt have autolatency or proformance wes hes got 3.4 there 4+ things :)
Posted Fri 05 Jan 07 @ 4:59 pm
Well, i did - no chance. I switched off all extras in windows, use a power-configuration, tweaked my lap where i could. I also reinstalled VDJ, the hercules driver and also reinstalled the SB-Card tried to change the configuration of V-DJ..i'm really confused.
I'm wondering also, that i get a VDJ Error-Message if i close the program.
I saw the IRQ-Story and saw also, that The soundcard is sharing the irq with the a usb port. Maybe the problem ?
One information before was wrong. My CPU is a Celeron, not a Centrino.
Posted Sat 06 Jan 07 @ 6:23 pm
Posted Sat 06 Jan 07 @ 6:26 pm
Well, i will tomorrow ;-) Have a Gig tonight - never touch a (just) running system... :-))
Posted Sat 06 Jan 07 @ 6:31 pm
good luck =)
Posted Sat 06 Jan 07 @ 6:36 pm
