Topic: DVD Ripper Crackling Sound
Redownloaded Numarks Cue on my other Desktop to try out. I loaded a non Encrypted DVD and got Crackling Noise and Messed up Video. Whats up with that?
Posted Wed 03 Jan 07 @ 10:14 pm
what is the spec of this new machine?
- Turn off keylock
- Turn off safemode in performance tab
- Make sure latency is set to AUTO in performance tab.
If you need further tweaking, lower performance slider BUT ALWAYS KEEP LATENCY AUTO!
If the video is messed up also I would check the video codecs that you have installed.
I hane not installed any codecs except what was already installed. It does the same thing on both computers.
Where is Keylock Located. Found Safe mode.
