I have the dj console mk2 and everytime i use the knobs for the left deck specially the bass it returns it to the full - side .no matter what i do.
Posted Fri 29 Dec 06 @ 9:56 pm
could you be more specific please
when did this start
what config do you have?
for reset gain and match pitch? and match gain?
when did this start
Posted Fri 29 Dec 06 @ 9:58 pm
Match pitch is disabled,reset macth gain is at gain is at always match
Posted Sat 30 Dec 06 @ 2:57 am
try dissabling always match gain , and eq reset
Posted Sat 30 Dec 06 @ 12:01 pm
i tried all that and still nothing..Thanks for the help guys.
Posted Sat 30 Dec 06 @ 3:06 pm
so what ever you change u get high bass?
Posted Sat 30 Dec 06 @ 3:11 pm
No the opossite it drops the bass on the left deck only
Posted Fri 12 Jan 07 @ 12:56 am
I think you have to put your soundcables both to the output 1/2 , not 3/4.
I am not sure if that's your problem.
Posted Fri 12 Jan 07 @ 8:18 pm
