Forum: Old versions
Topic: help me
do you have to buy pro version to play 1 song and preview another
Posted Tue 26 Dec 06 @ 9:43 pm
yes ;)
wel i wish i new that earlier iv just bought a sound card for my laptop :(
what are you using now then?
i bought an hercules control mp3 and i thought id need a soundcard for my laptot? should hav stuck with the decks ha! ha!
https://virtualdj.com/fusers/modifuser.html
add your serial
you will need a cheap external soundcard
u can get them for about 20 £ or 40 $
to alow one to preview and one to play
ul need pro to use this tho
The hercules mk2 has a built in dual soundcard, and works out of the box with VDJ (mix, prelisten etc)
The Hercules mp3 does NOT have a soundcard, but supports the use of ONE soundcard. To prelisten that ONE soundcard has to be a 4.1/5.1 soundcard, where you have main out at channel 1 out, and prelisten to rear out.
Such external usb 4,1/5.1 cards are very cheap....:)
i payed £80 for my sound blaster external soundcard. and the guys here are trying to sort my serial owt
because i lost my password nd couldnt use it again with a new email.
then just use that card
when u get pro ;)
try the 4.2 demo:)
