Forum: Old versions
Topic: Help with PLugIn
Is there a way to have the 32 or 16-Band Equalizer
enable on deck 1 &2 all the time without having to select the effect button every time you add a song.
Thanks
Posted Mon 25 Dec 06 @ 2:26 pm
Thanks
Download DJCel's registry tool, and un-check the Clear Effect on Load, then apply and try again.
https://virtualdj.com/addons/download.html?addon_id=2170
cstoll
Ware do I install it
thank you
Save it to your VirtualDJ folder and then create a shortcut to the desktop.
*Actually it doesn't matter where you install it as it just makes registry changes for you.
If you have never used it, you will like some of the registry options.
Have fun.
cstoll
