Forum: Old versions
Topic: My friend needs help...!!!
I have a friend that uses vdj 2.0 and he doesnt have access to the internet....he is looking to find a way to be able to listen to one channel on his earphones for pre-mixing..while the other channel plays on the speakers..(like u would with turntables and mixer)...is this possible...if yes...what is needed and how will he be able to set up...he is currently using his laptop....He has 2 soundcards on his descktop...We went thru the site and read about a "stereo splitter or y-splitter"...he bought it and cant figure out a way to split the 2 vdj turntables to work like real turntables....Please help...Does this version support the "stereo splitter- ysplitter" or not...does he need to upgrade in order to perfom his task...???
Posted Tue 19 Dec 06 @ 2:34 pm
Sice Virtual DJ 1.0 you can use two sound card, but only the pro user receive service support in this forum, if you and your friend are interested to VDJ software buy it https://virtualdj.com/purchase/
