Forum: Old versions
Topic: Help, to configure ASIO MODE with Edirol UA-101
Hi everyone!
i have the Edirol UA-101, i need that someone help me to use it with Asio Driver.
I install the drivers of the edirol ua-101. aftre that in Virtual Dj, i:
I'm only going to use now a Laptop
Imputs:None
Outputs:Singel output
sound hardw: ASIO
in the ASIO Driver, i select Edirol UA-101
TGhere is a button called ASI CONFIG..., that is not working (dont do anything)
With this configuration, when i play a song, it's not playing ( dont start when i select Play) and when i finish the Virtual dj, an asio error message apear.
cherss
Dj Pillo
Posted Tue 19 Dec 06 @ 10:10 am
sbangsPRO InfinityMember since 2004
try using the asio4all driver instead
www.asio4all.com
download and install
then run vdj pick
asio card
then driver asio4all , then press config you will now see a list of cards on your pc choose the Edirol UA-101 and enable it , dissable the others
press aply
go to proformance choose Autolatency
you should now be fine :)
Posted Tue 19 Dec 06 @ 4:28 pm
Cherrs i have done!
Now it's working.
I need to change the configuration of the asioforall?
- Latency conpensation IN : 32 Samples?
- Latency compensation Out : 32 Samples?
- Use hardware buffer?
- Buffer Offset: 10ms?
- Always resample 44.1 khz <> 48 khz?
- Force WDM driver to 16 BIT?
- Asio Buffer sice: 512 samples?
I change the virtual Dj confiration:
Latency : AUTO
The other options, what is better?
Cherrs For all
Dj Pillo
Posted Wed 20 Dec 06 @ 2:04 am
if it works , no need to change things :)
Posted Wed 20 Dec 06 @ 2:33 am
ok, thanks
Salud
Cherss
Dj Pillo
Posted Wed 20 Dec 06 @ 9:43 am
