Topic: x-session pro freezing VDJ
I just purchased the x-seesion midi controller and set it up, no problem... except it keeps causing VDJ to crash over and over again. Sometimes after 3 songs and other times within a 1/2 hour. Has anyone else experienced this problem or any ideas what the problem can be? I even tried adjusting the performance to the lowest values but it still did the same thing. After I unplugged it I had no other problems with VDJ.
Funkmasterfrank
Posted Sat 16 Dec 06 @ 10:54 pm
Do NOT assign midi values for effects, it will crash the program.
Best to stick with keyboard shortcuts for now until it can be taken care of.
are you joking? to use for effects is one of the reasons i have just ordered an x-session pro! its nice when things just work isnt it?!
Has there been any update for the x-session pro to be able to assign effects to the controller?
Funkmasterfrank
yes;)
Its fixed in 4.2
Nor,
I heard from someone who has the x-session and 4.2 and he said there is nothing more you can do in 4.2 than 4.1 that works. There is still some freezing issues and no more effect parameters are working than the 1st one. Have you confirmed this?
I don't have time at work to keep trying and having crashes to VDJ as we have customers there from the get go.
Can someone from the DEV team give me a clear heads up of whether it now works or not??
Still some mixed yes's and no's in the forum. Someone says it been fixed in 4.1 but that's the version I was up to when it didn't work.
It would be nice to see it work, not nice in my club to see VDJ crash for what seems to be a simple problem that the TEAM can fix!! My old x-session and Hurcules works great so I don't get it... isn't midi always midi. What makes the x seesion pro crash? I spoke to m-audio tech support and they told me the midi is the same as all their products.
Funkmasterfrank
the x-session is fixed now :)
