Hi
I've found an external Conceptronic USB sound card:
http://www.conceptronic.net/site/desktopdefault.aspx?tabindex=0&tabid=200&Cat=30&grp=3010&ar=195&Prod_ID=1351&Prod=CSOUNDU&subid=550
I'm planning to buy mp3 dj control and this soundcard to be able to mix using monitor hability, is this external USB card fully compatible with VDJ?
Thanks
Thanks
Posted Thu 14 Dec 06 @ 4:06 am
im not sure
id recomend a more known card like u46dj
Posted Thu 14 Dec 06 @ 1:00 pm
skyfxl wrote :
im not sure
Only if you will work with tcv's or tccd's. If not you can use 5.1 soundcard like sb audigy2 nx (usb) or sblive (usb too).
Posted Thu 14 Dec 06 @ 5:30 pm
Hi again
I have one soundcard already per computer (both on my PC and my laptop). I want to get an additional soundcard so that I can monitor/prelisten songs without using splitting into two mono channels. So that I minimize the cost I want to buy an external usb soundcard so that I can use it both on my laptop and desktop PC.
Since I already have one card, I don't need to buy a card with more than two channels (I'm trying to keep it cheap) :P
What does tcv and tccd mean? I'm only going to use Virtual DJ with DJ mp3 control
Thanks very much
Thanks very much
Posted Fri 15 Dec 06 @ 5:14 pm
they are timecoded vinyl and timecoded cd
https://virtualdj.com/products/timecode/
Posted Fri 15 Dec 06 @ 5:16 pm
