Topic: MAYA44 USB
I am trying to find a new maya 44 USB can anyone help me?
Posted Sun 10 Dec 06 @ 7:40 am
they dont make them anymore, the substitute for it is u46 dj wich can be found on ebay for bout $200.00.
thank you I think I will go with the Gigaport AG
im told u46dj is good :)
A little birdie tells me the U46Dj is also discontinued....
nooooooooooooooooooooooooooooooooooooooooonooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooo, it cant be!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!, the u46 dj cant be disconntenued
skyfxl, is he right? is it discontenued?
According to 3 supplies in Australia it is true.
I also emailed ESI twice about it and am yet to get a reply from any of them.
I couldnt believe it when they told me....
just in astralia????? cauze i live in the us, whats gonna replace u46 dj? if they dont cell it anymore? can they still be found on ebay? cause im getting one
fearnot numark virtual vinyl out soon;)! FEAT numark CUE Feat Virtual Dj (tisnt that a mouthful lol)
all in one soundcard and timecodes
yeh but i sin the price will the numark be the same as the vDJ
numark cue yes
but you will pay more because your buying a soundcard 2
Screw Maya and the UDJ46, buy M-Audio Torq and use the soundcard that comes with it for Virtual DJ.
is u46 dj still being made????????????
aparently its comming to an end soon
