Forum: Old versions
Topic: Need help going live!
markdPRO InfinityMember since 2003
I am planning on using virtual dj with time coded cd's for the first time live tomorrow night at my gig. I have a few questions before doind so
1. i am using a firebox running through a firewire pcia card for my laptop thats 400bps do i need one that supports 800mbs to avoid skips or freezes?
2. My laptop is dell 1.6ghz inspiron 600m it has 512mb ram is this enough?
3. aany advice or warnings to prevent a disaster?
thanks in advance for the help here!
Posted Wed 06 Dec 06 @ 7:22 pm
sbangsPRO InfinityMember since 2004
all should be fine :)
if u find that the system is over tasked try lowering your proformance tab to fast
just remember stay calm if u worry about problems , ur more likey to make mistakes
Posted Wed 06 Dec 06 @ 7:26 pm
