Hello All, I downloaded the trial version of vdj ver 4.1r2 to see how i would feel connecting to a 3 channel mixer. I came across this problem:
I selected in Sound Setup
Outputs: 3 lines mixer
Sound Cards: Hercules dj console and sb live bit external
The thing is that vdj will play always the output number 2 in MK2 very low, I mean you almost can not listen to what is playing in that channel. No matter if I select desk A,B or samplers, output 2 will always be very low.
If I select creative live, both channels work ok.
I believe it is that vdj is assingning a wrong channel to hercules (eg. back instead of center)
Is there a way to make this work? tnx in advance
Posted Sun 19 Nov 06 @ 2:33 am
boost volume on mk2 contol pannel
Posted Sun 19 Nov 06 @ 2:38 am
Both Channel are at maximum level in hercules CP
Posted Sun 19 Nov 06 @ 2:42 am
how bizzar
will do some thinking
are they aslo max on the main volume control for that card?
Posted Sun 19 Nov 06 @ 2:45 am
The volume in windows cp for that card is set around 95 %.
If I select speaker & headphones - 4.1 card - mk2 in sound setup, everything works great. The problem starts when I select 3 line mixer.
Posted Sun 19 Nov 06 @ 2:50 am
have u enabled external mixer in the mk2 config
https://virtualdj.com/forums/45484/Hardware_Technical_Support/Hercules_MK2_with_EXTERNAL_MIXER_setup_for_VDJ3_and_VDJ_4.html
Posted Sun 19 Nov 06 @ 2:55 am
yes, I enabled external mixer in hercules cp, I have checked after starting vdj that it doesnt reset the settings. I also tried without external mixer enabled, but it didnt have any effect.
btw, thank you for trying to help me :-)
Posted Sun 19 Nov 06 @ 3:01 am
sure thing will keep thinking
Posted Sun 19 Nov 06 @ 3:04 am
Any MK2 user using an external 3 channel mixer that could confirm it that setup work fo them?
Posted Tue 21 Nov 06 @ 11:34 am
