I need help setting my programs up for broadcasting. I've uploaded Winamp and I am currently running a unregistered version of VDJ4. I've also downloaded the Shoutcast server to connect VDJ to Winamp. I thought I had it all set up and ready to go but I'm getting a "encoder error" when I try to lauch a broadcast from VDJ.
Any ideas on what I'm doing wrong and what I can do to fix the problem?
Posted Sat 18 Nov 06 @ 10:50 am
what encoder are you trying to use?
Posted Sat 18 Nov 06 @ 12:27 pm
The only encoder that I'm running is the one that runs from that ShoutCast source in Winamp. I have it set to 25kbps/22.050kHz,mono. Is this set up right? Or should I be running something completely different?
Posted Sat 18 Nov 06 @ 8:52 pm
http://www.virtualdj.com/forums/59741/General_Discussion/The_Ultimate_Guide_to_Broadcasting_With_Virtual_Dj_).html
have a lil read:)
aslo on shoutcast pic take source from soundcard:)
have a lil read:)
Posted Sat 18 Nov 06 @ 8:58 pm
skyfxl, please use bbcode to add links. In this case the width of the forum will remain normal. For example, this is the same link.
Ewout
Ewout
Posted Sun 19 Nov 06 @ 12:07 pm
I read one other thread that addessed this problem, but , there was no definite answer. I am running virtualdj through the Shoutcast DNAS server, but the url that is attached to my station name is
http://virtualdj.com. How/ Is it possible to change this to a new/different URL ?
Posted Sat 10 Feb 07 @ 5:59 am
this may be possible with a registry change i will check and get back to you
Posted Sat 10 Feb 07 @ 1:50 pm
