As vdj doesn't get the track analysis right all the time how do I correct it?? i've read in a few threads that you can adjust cbg manually - does this apply to the mk2 edition as I don't seem to have the option to assign a short cut key to it. If you can't is there another way to do it without creating a short cut?
Posted Tue 14 Nov 06 @ 11:46 pm
In my blog there is a method.
Posted Wed 15 Nov 06 @ 1:29 am
i have already tried using instructions off your blog and dj norways but i don't get the option to assign key after putting value in - am i missing something????
Posted Wed 15 Nov 06 @ 4:02 pm
When you open the menu, select rhythm, select adjust cbg, AND THEN PRESS THE KEY YOU WANT. That key will show up at the top of the page, in the key box. Then you can change the value to what you want.
Posted Wed 15 Nov 06 @ 11:09 pm
SORTED!!! Cheers for that :)
Posted Thu 16 Nov 06 @ 10:40 am
