Hi,
The following error apeares when i start up virtual dj with Asio modus enabled on the the hercules dj console (MK1) : "error in the sound driver of Directx".
If I disable this option there's no problem.. but I prefer using the asio modus. Anyone any idea? I installed all the neccesary hercules drivers..
Wouter
Wouter
Posted Tue 14 Nov 06 @ 4:19 pm
Try using a USB hub, worked for me to get rid of these errors.
Posted Tue 14 Nov 06 @ 7:23 pm
get 4.1r2 demo this problems now fixed
Posted Tue 14 Nov 06 @ 7:36 pm
ummm.... what if the demo expired!!!
i am using home version (w/MK2).. i bought the TCV i downloaded the trial version on a diff computer (laptop) but it tells me 0 days left on trial version.
if i get the ASIO drivers working NOW i get an error TCV cannot be found?
sometimes i get a green waveform but the red line is flat!!
AAARGH
AAARGH
Posted Tue 14 Nov 06 @ 10:45 pm
reinstall home edtion should solve it
check your cables are grounded aslo
and that they are plugged in
aslo what needles (stylus) are you using
Posted Tue 14 Nov 06 @ 11:28 pm
I solved my problem installing asio 4 all, you should try it!
www.asio4all.com
hope this help.
santosac46
www.asio4all.com
hope this help.
santosac46
Posted Wed 15 Nov 06 @ 7:22 pm
