is it possible to plugin usb vinyl decks into virtual dj and how?
Posted Sat 11 Nov 06 @ 5:33 am
Yes, it is. look here: https://virtualdj.com/blog/Dams/blog738.html
You just have to replace yout MK2 with maya44 sound card.
And you need TC vinyls: https://virtualdj.com/shop/
Posted Sat 11 Nov 06 @ 9:59 am
yes you use those usb decks as soundcards
and you can use your mk2 as an out
Posted Sat 11 Nov 06 @ 2:59 pm
i beleive uve both missed the point. I think hes referring to CD/Vinyl decks which have USB conectivity. Like the iCDX. The answer to that is, for all I know there is iCDX which i supported and nothing else to the extent of my knowledge
Posted Sun 12 Nov 06 @ 4:26 pm
yeah thats what i mean "CD/Vinyl decks which have USB conectivity" ,thanks for the advice. any other suggestions would be apreciated.
Posted Fri 01 Dec 06 @ 3:28 am
we have not missed the point
plug them in and select them as soundcards
that way the singal is recived from them as inputs
then select the mk2 as the output card
then the music can be heard externaly
Posted Fri 01 Dec 06 @ 10:31 am
i only have the dj control mp3 not the MKII, is it still possible?
Posted Mon 11 Dec 06 @ 7:00 pm
use your internal soundcard to send out however
i think u might need pro to use all these different cards
Posted Mon 11 Dec 06 @ 7:02 pm
