Hi, as most I have a TCV sound question. OK when I'm using the TCV, everything sounds just fine normally playing, but when I touch the vinyl to scratch it basically sounds terrible, it sounds much like collecting coins in the nintendo game mario (if that helps any?) So I'm sure this is a touch of the button problem, but not sure what? Any help would be great! I'm using VDJ 4.1 btw.
Posted Sat 11 Nov 06 @ 2:28 am
https://virtualdj.com/forums/58120/Hardware_Technical_Support/Guide_To_set_up_tcv_with_mk2_console__)_.html
need to change ur asio buffer i think
that should help :)
guide explains
that should help :)
guide explains
Posted Sat 11 Nov 06 @ 2:30 am
do you have enhanced scratch algorthm on and what buffer size you using ?
Posted Sun 12 Nov 06 @ 4:16 pm
yes thats a good bet
Posted Sun 12 Nov 06 @ 4:53 pm
