Forum: Old versions
Topic: does regular mixer works with virtual dj?
bbj2kHome userMember since 2006
i was wondering if the regular mixer works with virtual dj?
i don't have credit card and i couldn't find "DJ Control MP3" in my city (vancouver, british columbia)
if i don't have turntables, can i just virtual dj & a mixer (i will be getting cdjs when i have enough money)
thanks
Posted Tue 31 Oct 06 @ 2:50 pm
sbangsPRO InfinityMember since 2004
a regular mixer will work but
it wont control virtual dj
unless its midi enabled
you will need two soundcards
to use it aslo
or a 2 channel out soundcard
Posted Tue 31 Oct 06 @ 2:57 pm
phillydjPRO InfinityModeratorMember since 2004
Yes, you can Virtual DJ is a standalone program
how do i find out if certain mixer has midi support
i need a mixer that will control inside the virtual dj mixing
my budget for a mixer is around $500 cdn
i have a sb x-fi fps sound card, do i really need another one of the same?
Posted Wed 01 Nov 06 @ 12:27 pm
If you want a mixer that controls vdj and supports midi, you can use the bcd2000 or the hercules mk2,regards.
Posted Wed 01 Nov 06 @ 1:47 pm
Posted Wed 01 Nov 06 @ 3:04 pm
You can check on e-bay, some users accept wire transfer.
Posted Wed 01 Nov 06 @ 3:09 pm
yeh , or you can link payments to your bank on ebay
Posted Wed 01 Nov 06 @ 3:12 pm
so i guess there isn't any in canadian stores?
i pefer somewhere close where i can return within walking/driving distance
Posted Thu 02 Nov 06 @ 1:21 pm
how about NUMARK DXM06 2 Channel DJ Mixer
do i need another sound card (sb x-fi fps)???
Posted Thu 02 Nov 06 @ 2:20 pm
one for each channel i belive
Posted Thu 02 Nov 06 @ 3:49 pm
