Forum: Old versions
Topic: Effects ?? Help ?
Well i have had the VDJ software for ages now and i just downloaded some extra effects off Ares
and i have saved them in my files, there some sort of wierd file anyways, i know how to add samples you click on it and click load, now what do you do with effects ????
there is no load section or click button Help :(
and, ive tried clicking on the effect then it says open it with ??? so clicke don browse and found VDJ and it wouldnt load it still up help anyone please......
Posted Thu 26 Oct 06 @ 5:30 pm
Where did you get these effects ?
Posted Thu 26 Oct 06 @ 5:34 pm
off www.ares.com
downlaod site.. all the samples work fine which i downloaded in the same package, it had samples and effects, the samples work i cant seem to upload the effects how do you do that ?
Posted Thu 26 Oct 06 @ 5:37 pm
And still a demo user ?
Posted Thu 26 Oct 06 @ 5:40 pm
nope i downloaded the full version the 3.0 version :D good shit :D
Posted Thu 26 Oct 06 @ 5:46 pm
bogartPRO InfinityMember since 2004
If you have ourchased the program then you must register it in order
for people to know that you have a legal version. You will get more help that way
Posted Thu 26 Oct 06 @ 7:14 pm
phillydjPRO InfinityModeratorMember since 2004
Sorry DJMadMatt theres no support for effects not downloaded from this site
Posted Thu 26 Oct 06 @ 8:18 pm
