Forum: Old versions
Topic: Help with dj console and vdj please
netman97ControlleristMember since 2005
ive had vdj and the hercules dj console for a while now & everything was fine..
had to put another hard drive in my computer & reload everything .....
now when i use vdj and a song is playing i cant speed up the song or slow it down a little to cath up the beat with the jog wheels because if i try to move the wheel just a little forward it speeds up the song so much that it sounds like i put the pitch adj as fast as it can go and if it is too much ahead and i want to slow the song down a little if i just move the wheel backward a little it sounds like i am almost stopping the song........
i have reloaded everything 3 times... and have NEVER messed with any of the setteings to vdj or to the dj console... any ideas of what is going on
i used to be able to move the wheel forward a little & catch up without hardly noticing, now when i go forward it sounds like the chipmunks are singing.......
your help would be appreciated.........thanks
Posted Wed 25 Oct 06 @ 5:04 am
anyone have any ideas ???????
Posted Thu 26 Oct 06 @ 7:39 pm
Turn OFF "scratch with jogwheels" in the controller settings in VDJ ;)
Btw, this option is only available in full version of VDJ, so I take it you are trying a demo or a "demo" .....
Hope you like the software, and buy the full legal version soon;)
Posted Thu 26 Oct 06 @ 7:41 pm
thanks for your help.......
just cant understand why it worked fine for months.
didnt start having the problem until i reloaaded everything
and didnt touch any settings
Posted Thu 26 Oct 06 @ 7:47 pm
Its not available in the 1.09 version you got with the console.. ;)
But the full version of Virtual DJ can scratch with the jogs... So you probably installed a demo/"demo":)
And hopefully if you like the software, you will buy the full legal version one day:)
Posted Thu 26 Oct 06 @ 8:00 pm
not trying to be a pain , i think you misunderstood.
i am NOT trying to scratch with the jogs....
was just trying to move them forward a little bit to cath the beat up
and even if i move it a little bit the songs speed up really really really fast
just was trying to figure out why
and as far as what i installed
i installed what came with the dj console...( it may be a demo even though it doesnt say that )
if i gan get it workin right MAYBE i will buy the full version....
Posted Thu 26 Oct 06 @ 8:19 pm
No worries;)
The reason it moves to fast, is that the scratch for jogs are enabled..
Just turn scratch off, and you can nudge in small movements:)
Posted Thu 26 Oct 06 @ 10:55 pm
