Forum: Old versions
Topic: problem with vdj4 nuo4
stefdjPRO InfinityMember since 2006
hi,
i too have had problem with ecler nuo4 /vdj4.
all major functions have been mapped out ie. channels eq, faders , etc............no problems with them at all. I have also set up nu04 to transmit midi note on /note off messages on the pots as oppose to control messages, i can therefore program 1 pot to scroll through the samples available and then push it to play the sample. all this works really well. However if i try the same set up with the effects it freezes, fairly randomly but it will always freeze, i dont get any death screen but obviously have to control alt del. and restart vdj. Strangely on deck 2 it worked with the effects for a while, but not on deck 1, then in between freezes it swapped , worked on one not on 2.( strange)
I havn't used 3.4 so i dont know if it would work or not.
You guys may well have a far better idea why this is happening than me, but do think it is possible that because the samples are defined by a number ie 1/siren . 2/ etc.etc
and the effects are not vdj is getting confused somehow?????????????????(value =+1)
Any thoughts would be useful.
Posted Thu 19 Oct 06 @ 12:03 am
