naw im using 4.2r2 but i have no grounds..where do i ground the turntables at, they have no slot for ground?!
Posted Thu 14 Dec 06 @ 11:57 pm
FIXED!!! apparently i changed the speed of the record in the options from 33 to 45 and i switched it bak and now it works awesome..
one more procblem now though!!, every so often, some songs will be halfway done then they randomly go back to the beginning..what did i do now!~?
also!, when i scratch, its no crisp, still a little whining noise it sounds like..any suggestions?!?
thanks alot
thanks alot
Posted Fri 15 Dec 06 @ 1:00 am
Can u pick asio as a soundcard and then asio driver mk2?
Posted Fri 15 Dec 06 @ 10:13 am
ya it lets me do that, and that what i have..
are the turntables supposed to be on phono or line in? and what about with the mk2?
Posted Fri 15 Dec 06 @ 8:02 pm
phono ;)
aslo check ur groundings
Posted Fri 15 Dec 06 @ 8:17 pm
yeah i was asking about that before..where do i ground to on the tables, there is no slot for "ground"
Posted Fri 15 Dec 06 @ 9:37 pm
on mk2 next to inputs are grounding posts
ground these to those on your decks
Posted Fri 15 Dec 06 @ 10:02 pm
thats what im saying...there are no slots for grounding on the tables
Posted Sat 16 Dec 06 @ 5:48 pm
ah
thats tough
is there any metal u can ground it to on the deck?
thats tough
Posted Sat 16 Dec 06 @ 6:02 pm
o well!!
have u seen the dj getdown clip? is that what the scratches are suppoed to sound like? my sounds really really digital..nothing compared to his scratches..:O(
I TRied serato and it was totallllyyy different
Posted Sat 16 Dec 06 @ 8:28 pm
in 4.1r2
the it sounds alot better and i have acess to a vinyl noise plugin to add that extra realism
Posted Sat 16 Dec 06 @ 8:36 pm
if i use the usb46dj card thingy instead of the herc console, would it make a difference in the scratch quality?
Posted Sat 16 Dec 06 @ 8:43 pm
worth a shot
but dont loose hope with the herc just yet try the 4.1 demo
Posted Sat 16 Dec 06 @ 8:52 pm
i have 4.1r2!
i dont know what else to try!! :o(
if u can make my scratches sound as clean as his ill be in good business!
Posted Sat 16 Dec 06 @ 9:01 pm
325bimmerdan wrote :
i have 4.1r2!
for any one having this problem ?
http://www.virtualdj.com/forums/61631/Hardware_Technical_Support/__ALL_How_to_Get_2ms_latency_on_your_mk2_(improve_timecode_and_sound_quality).html
Posted Sun 24 Dec 06 @ 7:10 pm
a new tip for 4.2 users :)
1. press auto config 2 times
should now be 100%
2.
press match to try to match the config
if it doesnt work
try step one on the other deck
should now be 100%
2.
if it doesnt work
Posted Mon 25 Dec 06 @ 3:02 pm
Hi,
Just a shot in the dark, but if i have the MK2, 2 turntables and TCV. Do i still need an external mixer?
Can i not just use the MK2 as the mixer and plug the speakers into this?
Thanks
Thanks
Posted Tue 02 Jan 07 @ 1:58 pm
no mk2 is good on its own aslo
but some folks like an external mixer its entirely up to you :)
Posted Tue 02 Jan 07 @ 2:07 pm
Thanks.
just trying to keep downs costs (initially anyway)
Posted Tue 02 Jan 07 @ 2:10 pm
can i use timecoded cds on v3.4 i just got the program
Posted Fri 12 Jan 07 @ 8:44 am
