Hi
I've received my new Hercules DJ Control this morining and it's been shipped with V3.0. If I purchase V4.0 will this work with DJ Control ?
I wanted to check before installing 3.0
Also, where do I find my serial number to add this to my forum profile ?
Thanks in advance
Thanks in advance
Posted Tue 17 Oct 06 @ 9:34 am
You can add your serial number here https://virtualdj.com/fusers/modifuser.html and try to downlaod the trial version 4.1 here https://virtualdj.com/download.html
Posted Tue 17 Oct 06 @ 9:35 am
yes it is supported :)
infact i use the mk2 varient :)
Posted Tue 17 Oct 06 @ 11:13 am
Im assuming you mean I should download the trial to check if it works ? If so I'll give it a blast tonight.
It won't cause any problems if I find it doesnt work and I need to uninstall then install 3.0 will it ?
Posted Tue 17 Oct 06 @ 11:14 am
Cheers matey
Posted Tue 17 Oct 06 @ 12:05 pm
He probably means that you can have a try at the newest version if you want, and if you like it over 3.0, then consider on registering VDJ.
If virtual DJ 3.X is enough for your use... stick to it.
I was using 1.09 (version that came with hercules mk1) for a long long time just because I didn't need more.
Anyways, If you modify your profile to show that you own a dj control, probably you'll have an update from 3.0 to 3.4, When I bought my hercules mk2 happened to me, but since I was using 4.0, I just downloaded the upgrade and left it there.
Welcome to the comunity
Posted Tue 17 Oct 06 @ 12:49 pm
