Topic: Hot Cue Buttons
HaywardPRO InfinityMember since 2005
Does anyone find the HOT CUE buttons useful?
I personally would prefer the cue count down indicators in this position.
Posted Sun 15 Oct 06 @ 1:39 am
I personaly find the HOT CUE buttons on the default 4.x skin annoying. I'm changing mine to act like cue buttons in the 3.x version.
Posted Sun 15 Oct 06 @ 1:45 am
If I knew how to get around the XML I would do the same, I wish the EQ buttons were on the Default Skin instead of these, I also don't like the behavoir of the SYNC button.
I wish it would sync and play on the left click like the older versions.
If you can tell me how to change this I can try.
Posted Sun 15 Oct 06 @ 1:58 am
I agree 100%
I use the hot cue mapper with my dac-2 that was available for download (forgot who wrote it) but since it's not compatible for 4.1.....
As for the skins, - i use the old hercules dj console skin, it works ok. I never did like the spinning records on the default skin, looks like a video game.
DJ Marcel
Posted Sun 15 Oct 06 @ 3:42 am
NiemsPRO InfinityMember since 2006
I think the cue lineup on Mixstation is one of the best. The hotcues aren't that nice I agree, but its pretty simple to edit them to become like the old cues
Posted Sun 15 Oct 06 @ 1:02 pm
apopsisdjPRO InfinitySenior staffMember since 2003
In my keyboard shortcuts i use 4 cues per deck (F1-F4 & F5-F8)
The first cue is hot cue and the other are normal go_to_cue, while control+key does set_cue.
This works the best for me.
Posted Sun 15 Oct 06 @ 9:15 pm
