Alright, someone please tell me why the sound hits so weird when you hook up the Hercules to a dj system, any suggestions,
Posted Thu 12 Oct 06 @ 5:54 pm
I played in club with DJC sound card and sound it perfect! What problems do you have??
Posted Thu 12 Oct 06 @ 6:15 pm
Its like it needed more gain it was very low, do i need to boost the levels, im not trying to create distortion though, any suggestions, thanks
Posted Thu 12 Oct 06 @ 6:28 pm
![](http://i9.tinypic.com/33vgjtv.jpg)
Will give you about the same level out, as dj hardware ;)
Posted Thu 12 Oct 06 @ 6:36 pm
I had that problem when I just started using MK2, you need to execute the MK icon found in the system tray or Control Panel. From there you will be able to manupliate all your basic sound settings..Let me know if this helps........
Posted Thu 12 Oct 06 @ 6:39 pm
Man, u guys r good, LOL thanks
Posted Thu 12 Oct 06 @ 6:52 pm
Posted Thu 12 Oct 06 @ 7:15 pm
