Exactly how is an external usb sound card used to function with the headphone's listen in
feature.
When I used the ext . sound card, the sound only came out only from it to the headphones, and not out of the internal soundcard which was sent to the mixer/speakers.
How do I get the sound out to the speakers from the internal card AND fromthe usb ext. card to the headphones( so i can listen to songs in the list before I play them).
feature.
Posted Wed 11 Oct 06 @ 7:50 pm
you have to choose the 2 soundcard option, also make sure that windows keeps your internal card as the primary card, sometimes it like to make the usb the primary
just take a look at the sound options in the Windows control panel and see what card it has as primary
if it's the USB then change it to the internal card
Posted Thu 12 Oct 06 @ 5:11 pm
