Anyone know if this will work?? Im currently looking for an upgrade from my maya usb 44.
Posted Wed 11 Oct 06 @ 5:25 pm
Well i answered my own question. I went out and bought m-audio torq. The m-audio interface does in fact work and it works very well. However i must say, i didnt like m-audios software much!!! lololol. Ill mess with it some more though.
Posted Tue 17 Oct 06 @ 4:29 am
It would seem to reason that the BEST soundcard to use with VDJ is the one that is most well supported in VDJ. I think that is the ESI u46dj.
Posted Tue 17 Oct 06 @ 8:01 pm
Well depending on your budget and your needs. I can confirm that emu 1616m and the Motu Ultralite work great, and with almost 0 latency. I am currently using the Motu, you have more inputs/outputs so if you want to mess with ableton and other audio applications.
Posted Sat 21 Oct 06 @ 9:29 am
