I live in Serbia and I wan't to buy Dj Console but I don't wanna get a bad console so I must return it to Hercules, I wan't to be shure that it's ok from start! If you guys wait 2 weeks, I will wait half year... where I live. So, any problems new users (I mean 2 months in past)? Thanks!
Posted Tue 13 Jul 04 @ 3:05 am
there used to be, a fabric/firmware error..
but thats sorted out, and if you buy one now, you will not have any problems...
and even if you should (you won't), there are a free firmware that can be downloaded from Hercules fixing the "over sensitive jogwheel" problem
My hercules work like a charm ;)
Posted Tue 13 Jul 04 @ 4:01 am
Thanks DjInNorway!
Posted Tue 13 Jul 04 @ 4:27 am
Thanks Dj in Norway for all your very useful posts in this forum.
I just got myself a Hercules Console a few days ago and, contrary to what you say above, I still have the jog wheel problem.
I installed the latest drivers/firmware from the hercules site....
I'm curious if the problem will be fixed. (without sending it back for a fix)
I'll keep you posted...
Posted Fri 07 Oct 05 @ 12:49 pm
Turns out I have a console with bulk status 1 !
(bought it last week....)
Can I fix the problem just with the latest firmware/driver or do I need a replacement ?
Thanks
Thanks
Posted Fri 07 Oct 05 @ 1:52 pm
Tested it for an hour and had one problem.
I accidentally touched the left jog and as a result the music kept on playing in a lower pitch until I slightly moved the jog wheel.
Is this the bug or does the bug also happen while not touching the console whatsoever ?
Please tell me, so I can decide to send it back or not.
Thanks
Thanks
Posted Fri 07 Oct 05 @ 2:55 pm
WOW, my old nick post! A blast from the past! I think that you must replace it with new bulk version, no software will help you, saddly! That's why I never ordered Hercules, I'll wait for Behringer instead!
greetz
greetz
Posted Sat 08 Oct 05 @ 6:50 am
