I use Virtual Dj in conjunction with my Serato SL-1 and timecoded cd's... My issue is when I'm playing a video and mixing from one to the next, everything works fine for a few minutes... After a while, when I try to stop the deck that is playing the video, the deck stops but the video continues to play. I can't control the picture unless I use the stutter or pause on the software screen itself... That means I cannot scratch or mix in the next video... Why am I having this problem?
Posted Tue 26 Sep 06 @ 11:52 pm
what demo are you using? 3.4 or 4.0
Posted Wed 27 Sep 06 @ 1:20 am
4.0
Posted Wed 27 Sep 06 @ 4:30 pm
that is a software bug, contact e-spport and they will (hopefuly) give you a debugger version to recreate the fault, find out the cause, and fix it. SSL users haveing problems will ruffle some feathers because they want it to be a good advert
please bear in mind that the support of SSL products is for trial and demo purposes only and that alot more time has gone into the pro version
Posted Thu 28 Sep 06 @ 12:49 am
